Datasheet Texas Instruments LM22672MRE-ADJ/NOPB — Даташит
СерияLM22672
МодельLM22672MRE-ADJ/NOPB
1A SIMPLE SWITCHER®, понижающий стабилизатор напряжения с регулируемой частотой 8-SO PowerPAD от -40 до 125
LM22672/-Q1 42-V, 1-A SIMPLE SWITCHERВ® Step-Down Voltage Regulator with Features datasheet
PDF, 1.4 Мб, Версия: M, Файл опубликован: 5 ноя 2014
Pin88
Package TypeDDADDA
Industry STD TermHSOICHSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаADJL22672
Width (мм)3.93.9
Length (мм)4.894.89
Thickness (мм)1.481.48
Pitch (мм)1.271.27
Max Height (мм)1.71.7
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)1 A
Iq(Typ)3.4 мА
Package GroupSO PowerPAD
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)1.285 В
  • Evaluation Modules & Boards: LM22672EVAL
    LM22672 1A SIMPLE SWITCHER Regulator w/ Freq Adj or Synch and Precision Enable EVM
  • AN-1533 Overvoltage Protection Circuit for Automotive Load Dump (Rev. B)
    PDF, 83 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report discusses an over voltage protection circuit for automotive load dump.
  • AN-2020 Thermal Design By Insight, Not Hindsight (Rev. C)
    PDF, 568 Кб, Версия: C, Файл опубликован: 23 апр 2013
    This application report provides an in-depth discussion of thermal design.
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • SIMPLE SWITCHER Regulators Take Over Automotive Applications (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Power management applications, typically located on the front line of the automotive electronics system,can be subject to wide input operating voltage extremes resulting from load-dump and cold-crankingconditions. Careful selection of the power management electronics can provide added margin andprotection to the automotive electronics system. The simplest design is provided by a power manage
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
LM22672MREADJ/NOPB, LM22672MRE ADJ/NOPB
На английском языке: Datasheet Texas Instruments LM22672MRE-ADJ/NOPB
