Datasheet Texas Instruments TLC4502QDR — Даташит
СерияTLC4502
МодельTLC4502QDR
Усовершенствованный прецизионный двойной операционный усилитель LinEPIC с самокалибровкой 8-SOIC от -40 до 125
Family of Self-Calibrating (Self-Cal) Precision CMOS Rail-to-Rail Output Op Amps datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 2 апр 2001
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesShutdown
Approx. Price (US$)2.07 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)90
CMRR(Typ)(dB)100
GBW(Typ)(MHz)4.7
Input Bias Current(Max)(pA)60
Iq per channel(Max)(mA)1.5
Iq per channel(Typ)(mA)1
Number of Channels(#)2
Offset Drift(Typ)(uV/C)1
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)66
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)2.5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)6
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4
Vn at 1kHz(Typ)(nV/rtHz)12
Vos (Offset Voltage @ 25C)(Max)(mV)0.02
RoHSНе совместим
  • TLC4501 and TLC4502 EMI Immunity Performance
    PDF, 88 Кб, Файл опубликован: 31 дек 2013
  • DC Parameters: Input Offset Voltage
    PDF, 295 Кб, Файл опубликован: 27 мар 2001
    The input offset voltage, VIO, is a common dc parameter in operational amplifier (op amp) specifications. This report aims to familiarize the engineer by discussing the basics and modern aspects of VIO by providing a definition and a detailed explaination of causes of VIO for BJT, BiFET, and CMOS devices. Discussion centers around measurement techniques, data sheet specifications, and the effect o
  • Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
    This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
На английском языке: Datasheet Texas Instruments TLC4502QDR
