Datasheet ТI INA132UAE4 — Даташит
| Серия | INA132 |
| Модель | INA132UAE4 |
Дифференциальный усилитель малой мощности с одним питанием 8-SOIC от -40 до 85
Low Power, Single-Supply Difference Amplifier datasheet
PDF, 333 Кб, Файл опубликован: 27 сен 2000
- High-Voltage Signal Conditioning for Low Voltage ADCsPDF, 135 Кб, Файл опубликован: 15 июн 2004
Analog designers are frequently required to develop circuits that convert high-voltage signals to levels acceptable for low-voltage data converters. This paper describes several solutions for this common task using modern amplifiers and typical power supplies. Five examples of conditioning ±10V bipolar signals for low-voltage single-rail analog-to-digital converters(ADCs) are presented: - Precision Absolute Value CircuitsPDF, 100 Кб, Файл опубликован: 2 окт 2000
You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
Серия: INA132 (11)
- Semiconductors > Amplifiers > Difference Amplifiers
