Datasheet Texas Instruments TPS61258YFFT — Даташит
СерияTPS61258
МодельTPS61258YFFT
Высокоэффективный повышающий преобразователь 3,5 МГц в корпусе микросхемы.
TPS6125x 3.5-MHz High Efficiency Step-Up Converter In Chip Scale Packaging datasheet
PDF, 6.4 Мб, Версия: G, Файл опубликован: 16 июн 2016
Выходное напряжение 4,5 В 9-DSBGA от -40 до 85
Pin9
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаSAZ
Width (мм)1.4
Length (мм)1.4
Thickness (мм).425
Pitch (мм).4
Max Height (мм).625
Duty Cycle(Max)100 %
Iq(Typ)0.02 мА
Package GroupDSBGA
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Load Disconnect
Switch Current Limit(Min)3.3 A
Switch Current Limit(Typ)3.6 A
Switching Frequency(Max)3500 kHz
Switching Frequency(Min)3500 kHz
ТипConverter
Vin(Max)4.85 В
Vin(Min)2.65 В
Vout(Max)4.5 В
Vout(Min)4.5 В
  • Evaluation Modules & Boards: TPS61258EVM-766
    TPS61258 Chip Scale step-up dc-dc converters, 3.5-MHz high efficiency Evaluation Module
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61258 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61258YFFT
