Datasheet Texas Instruments THS6182DWPR — Даташит
СерияTHS6182
МодельTHS6182DWPR
Драйвер линии ADSL с низким рассеиванием мощности 20-SO PowerPAD от -40 до 85
Low Power Dissipation ADSL Line Driver datasheet
PDF, 1.8 Мб, Версия: H, Файл опубликован: 11 июн 2007
Pin20
Package TypeDWP
Industry STD TermHSOIC
Package QTY2000
МаркировкаTHS6182
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
2nd Harmonic88 dBc
3rd Harmonic107 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl100 МГц
CMRR(Min)48 дБ
CMRR(Typ)54 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)15000000 pA
Iq per channel(Max)12.5 мА
Iq per channel(Typ)11.5 мА
Количество каналов2
Offset Drift(Typ)50 uV/C
Output Current(Typ)600 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)450 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)13 нВ/rtГц
Vn at Flatband(Typ)3.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)20 мВ
  • Evaluation Modules & Boards: THS6182RHFEVM
    THS6182RHF Evaluation Module
  • Evaluation Modules & Boards: THS6182DWEVM
    THS6182DW Evaluation Module
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
На английском языке: Datasheet Texas Instruments THS6182DWPR
