Datasheet Texas Instruments LM73CIMKX-0/NOPB — Даташит
| Серия | LM73 |
| Модель | LM73CIMKX-0/NOPB |
В±1В°C Temperature Sensor with I2C/SMBus Interface 6-SOT-23-THIN -40 to 150
LM73 2.7-V, SOT-23, 11- to 14-Bit Digital Temperature Sensor With 2-Wire Interface datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 29 окт 2015
Купить LM73CIMKX-0/NOPB на РадиоЛоцман.Цены — от 37 до 314 ₽43 предложений от 17 поставщиков SENSOR DGTL -40C-150C TSOT23-6. Temperature Sensor Digital, Local -40°C ~ 150°C 13 b TSOT-23-6. Temperature Sensors - Analog and Digital Output... | |||
| LM73CIMKX-0/NOPB Texas Instruments | от 179 ₽ | ||
| LM73CIMKX-0/NOPB Texas Instruments | от 282 ₽ | ||
| LM73CIMKX-0/NOPB Texas Instruments | 314 ₽ | ||
| LM73CIMKX-0/NOPB Texas Instruments | по запросу | ||
| Pin | 6 |
| Package Type | DDC |
| Industry STD Term | SOT-23-THIN |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | T730 |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | .87 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.1 |
| Mechanical Data | Скачать |
| Addresses | 6 |
| Interface | I2C, SMBus, 2-Wire |
| Iq(Typ) | 320 uA |
| Local Sensor Accuracy(Max) | 1 +/- C |
| Рабочий диапазон температур | от -40 до 150 C |
| Package Group | SOT-23-THIN |
| Package Size: mm2:W x L | 6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG |
| Rating | Catalog |
| Special Features | Configurable Resolution,Programmable Alert,One-Shot Conversion,Shutdown |
| Supply Current(Max) | 550 uA |
| Supply Current(Typ) | 320 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2.7 В |
| Temp Resolution(Max) | 14 bits |
- Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
Серия: LM73 (4)
- LM73CIMK-0/NOPB LM73CIMK-1/NOPB LM73CIMKX-0/NOPB LM73CIMKX-1/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
LM73CIMKX0/NOPB, LM73CIMKX 0/NOPB
