Datasheet Texas Instruments TLV1544CDG4 — Даташит
СерияTLV1544
МодельTLV1544CDG4
10-разрядный АЦП, 85 тыс.
Low-Voltage 10-Bit A-D Converters w/Serial Control and 4/8 Analog Inputs datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 21 янв 1999
операций в секунду, сер. Выход, программируемое питание/Pwrdn/скорость преобразования, совместимость с TMS320 DSP/SPI/QPSI, 4 канала. 16-СОИК от -40 до 85
Pin16
Package TypeD
Package QTY40
МаркировкаTLV1544C
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
# Input Channels4
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Power Consumption(Typ)1.75 mW
Reference ModeExt
Разрешение10 Bits
Sample Rate (max)85kSPS SPS
Sample Rate(Max)0.085 MSPS
  • Interfacing the TLV1544 Analog-to-Digital Converter to the TMS320C50 DSP (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 28 дек 1998
    This application report presents two hardware solutions for interfacing the TLV1544 10-bit low-power analog-to-digital converter (ADC) to the TMS320C50 16-bit fixed-point digital signal processor (DSP). The report describes the interface hardware and shows three C-callable software routines which support the data transfer. In addition, it provides useful hints on the design of a typical system pow
  • Interfacing the TLV1544 Analog-to-Digital Converter to the TMS320C203 DSP (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 15 фев 1999
    This application report presents two hardware solutions for interfacing the TLV1544 10-bit low-power analog-to-digital converter (ADC) to the TMS320C203 16-bit fixed-point digital signal processor (DSP). The report describes the interface hardware and shows a C-callable software routine which supports the data transfer. In addition, it provides useful hints on the design of a typical system power
  • Interfacing the TLV1544/1548 Analog Digital Converter to Digital Processors
    PDF, 266 Кб, Файл опубликован: 1 авг 1997
    This Application Report describes the hardware and software requirements for interfacing an A/D converter to a DSP and to a MCU. The 10-bit A/D converter TLV1544 (4 analog input channels) and the TLV1548 (8 analog input channels) from Texas Instruments have been used to develop such interface. Example software code has been written showing how to program the DSP and the MCU to control the A/D conv
  • Low-Power Signal Conditioning For A Pressure Sensor (Rev. A)
    PDF, 469 Кб, Версия: A, Файл опубликован: 18 май 2015
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV1544CDG4
