Datasheet Texas Instruments UCC39002DRG4 — Даташит
СерияUCC39002
МодельUCC39002DRG4
Усовершенствованный 8-контактный контроллер распределения нагрузки 8-SOIC от 0 до 70
UCC2900x, UCC39002 Advanced 8-Pin Load-Share Controller datasheet
PDF, 1.2 Мб, Версия: I, Файл опубликован: 31 май 2016
Микросхема Чип управления батареи, Load Share Controller 8Pin SOIC T/R
UCC39002DRG4
108 ₽
UCC39002DRG4
147 ₽
UCC39002DRG4
UCC39002DRG4
Package TypeD
Package QTY2500
Маркировка39002
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Operating Supply Current2.5 мА
Operating Supply(Max)14.25 В
Operating Supply(Min)4.375 В
Share BusSingle-Ended
Special FeaturesUVLO
Startup Current2500 uA
  • Evaluation Modules & Boards: UCC39002EVM
    UCC39002 Evaluation Module
  • Load-Sharing TPS40050 Modules Using the UCC39002 Load-Share Controller
    PDF, 326 Кб, Файл опубликован: 13 апр 2004
  • Current Sharing in Redundant Systems
    PDF, 237 Кб, Файл опубликован: 8 янв 2010
  • Synchronizing Three or More UCC28950 Phase-Shifted, Full-Bridge Controllers
    PDF, 650 Кб, Файл опубликован: 13 сен 2011
    One of the key features of the UCC28950 phase-shifted, full-bridge controller is its ability to synchronize its main oscillator to an external clock source. In this way, multiple controllers can be synchronized to improve performance criteria of the end power supply. This application report expands the details of the synchronization capability of the UCC28950, provides examples of simple circuits
  • 48-VIN, 12-VOUT Loadshare System Using the UCC39002 with Three DC-DC Modules (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 14 фев 2003
    This application note features the UCC39002 BiCMOS 8-pin advanced load share controller and specifically illustrates equal current sharing between three 48-VDC to 12-VDC power modules, each rated for 8.4-A maximum output current, paralleled to supply a load of up to 24 A. The example uses high-side current sensing with the bias for the controllers supplied directly from the module?s output voltage
  • Pre-biased Output Voltage Startup Operation of the UCC28950
    PDF, 137 Кб, Файл опубликован: 1 авг 2011
  • U-163 The UC3902 Load Share Controller and its Performance in Distributed Power (Rev. A)
    PDF, 272 Кб, Версия: A, Файл опубликован: 13 дек 2002
  • U-129 UC3907 Load Share IC Simplifies Parallel Power Supply Design
    PDF, 251 Кб, Файл опубликован: 5 сен 1999
    The UC3907 family of Load Share Controller ICs provides all the necessary features to allow multiple independent power modules to be paralleled, so each module supplies only its proportionate share to total load current. Many power supply manufacturers have found it economically feasible to make standard modular power supplies which are easily paralleled for higher current applications. If speci
Серия: UCC39002 (7)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Load Share
На английском языке: Datasheet Texas Instruments UCC39002DRG4
