Datasheet Texas Instruments ADS8329IBRSATG4 — Даташит
СерияADS8329
МодельADS8329IBRSATG4
2,7–5,5 В, 16 бит, 1 MSPS, последовательный АЦП 16-QFN от -40 до 85
Low-Power, 16-Bit, 1-MHz, Single/Dual Unipolar Input, ADCs w/ Serial Interface datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 7 июл 2009
IC ADC 16BIT SAR 16QFN. 16 Bit Analog to Digital Converter 1 Input 1 SAR 16-QFN (4x4). Data Acquisition - Analog...
ADS8329IBRSATG4
576 ₽
ADS8329IBRSATG4
576 ₽
Рутоника
ADS8329IBRSATG4
1 015 ₽
ADS8329IBRSATG4
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка8329I AADS
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)1.65 В
INL(Max)1.75 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesDaisy-Chainable,Oscillator
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupQFN
Package Size: mm2:W x L16QFN: 16 mm2: 4 x 4(QFN) PKG
Power Consumption(Typ)13.2 mW
Reference ModeExt
Разрешение16 Bits
SINAD92 дБ
SNR93 дБ
Sample Rate (max)1MSPS SPS
Sample Rate(Max)1 MSPS
THD(Typ)-102 дБ
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS8329IBRSATG4
