Datasheet Texas Instruments TPS54810PWPRG4 — Даташит
СерияTPS54810
МодельTPS54810PWPRG4
4.5 to 5.5V Input, 8A Synchronous Step-Down SWIFTв„ў Converter 28-HTSSOP -40 to 85
4-V to 6-V Input, 8-A Output Synchronous Buck PWM Switcher with Integrated FETs datasheet
PDF, 725 Кб, Версия: B, Файл опубликован: 8 мар 2005
Pin28
Package TypePWP
Industry STD TermHTSSOP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)3.65 | 1ku
Control ModeVoltage Mode
Duty Cycle(Max)(%)90
Iout(Max)(A)8
Iq(Typ)(mA)11
Operating Temperature Range(C)-40 to 85
Package GroupHTSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Frequency Synchronization
Power Good
Synchronous Rectification
Switching Frequency(Max)(kHz)700
Switching Frequency(Min)(kHz)280
ТипConverter
Vin(Max)(V)6
Vin(Min)(V)4
Vout(Max)(V)3.3
Vout(Min)(V)0.9
RoHSНе совместим
  • Evaluation Modules & Boards: TPS54810EVM-213
    8-A, 4-6 Vin DC/DC Converter with Ceramic Capacitors and Adjustable Output
  • Evaluation Modules & Boards: TPS54880EVM
    8-A DC/DC Converter with Simultaneous Sequencing of Multiple Voltages
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Dual Output Power Supply Sequencing for High Performance Processors
    PDF, 6.0 Мб, Файл опубликован: 17 июл 2002
    Dual voltage power supply architectures are becoming commonplace in high performance microprocessor and digital signal processor (DSP) systems. To save power and increase processing speeds, processor cores have smaller geometry cells and require lower supply voltages than the system bus voltages. Power management in these systems requires special attention. Yesterday's power management ICs and app
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54810 (4)
На английском языке: Datasheet Texas Instruments TPS54810PWPRG4
