Datasheet Texas Instruments THS4631DRG4 — Даташит
СерияTHS4631
МодельTHS4631DRG4
Высокоскоростной операционный усилитель с входом полевого транзистора 8-SOIC от -40 до 85
High-Voltage High Slew Rate Wideband FET-Input Op Amp datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 17 авг 2011
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic(dBc)76
3rd Harmonic(dBc)94
@ MHz5
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)2.60 | 1ku
АрхитектураFET
Voltage FB
BW @ Acl(MHz)325
CMRR(Min)(dB)86
CMRR(Typ)(dB)95
GBW(Typ)(MHz)325
Input Bias Current(Max)(pA)100
Iq per channel(Max)(mA)13
Iq per channel(Typ)(mA)11.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)2.5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)95
Package Size: mm2:W x L (PKG)See datasheet (SON)
Rail-to-RailNo
Slew Rate(Typ)(V/us)1000
Total Supply Voltage(Max)(+5V=5, +/-5V=10)32
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at Flatband(Typ)(nV/rtHz)7
Vos (Offset Voltage @ 25C)(Max)(mV)0.5
RoHSНе совместим
  • Evaluation Modules & Boards: THS4631DGNEVM
    THS4631DGNEVM Evaluation Module
  • Evaluation Modules & Boards: THS4631DDAEVM
    THS4631DDAEVM Evaluation Module
  • Transimpedance Considerations for High-Speed Operational Amplifiers
    PDF, 193 Кб, Файл опубликован: 22 ноя 2009
    Designing high-resolution detection circuits using photodiodes presents considerable challenges because bandwidth, gain, and input-referred noise are coupled together. This application note reviews the basic issues of transimpedance design, provides a set of detailed design equations, explains those equations, and develops an approach to easily compare potential solutions.
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
На английском языке: Datasheet Texas Instruments THS4631DRG4
