Datasheet Texas Instruments OPA301AIDBVT — Даташит
СерияOPA301
МодельOPA301AIDBVT
Малошумящий, высокоскоростной, 16-битный операционный усилитель КМОП 5-SOT-23 от -40 до 125
Low-Noise, High-Speed,16-Bit Accurate, CMOS Operational Amplifier datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 13 июн 2007
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаAUP
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic75 dBc
3rd Harmonic79 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураCMOS,Voltage FB
BW @ Acl150 МГц
CMRR(Min)66 дБ
CMRR(Typ)80 дБ
GBW(Typ)150 МГц
Input Bias Current(Max)5 pA
Iq per channel(Max)12 мА
Iq per channel(Typ)9.5 мА
Количество каналов1
Offset Drift(Typ)2.5 uV/C
Output Current(Typ)70 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)80 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3 нВ/rtГц
Vn at Flatband(Typ)3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • High-Voltage Signal Conditioning for Low Voltage ADCs
    PDF, 135 Кб, Файл опубликован: 15 июн 2004
    Analog designers are frequently required to develop circuits that convert high-voltage signals to levels acceptable for low-voltage data converters. This paper describes several solutions for this common task using modern amplifiers and typical power supplies. Five examples of conditioning ±10V bipolar signals for low-voltage single-rail analog-to-digital converters(ADCs) are presented:
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA301AIDBVT
