Datasheet Texas Instruments UC2577T-ADJ — Даташит
СерияUC2577-ADJ
МодельUC2577T-ADJ
Простой повышающий стабилизатор напряжения 5-TO-220 от -40 до 125
UC2577-ADJ: Simple Step-Up Voltage Regulators datasheet
PDF, 366 Кб, Версия: A, Файл опубликован: 16 май 2003
26 предложений от 20 поставщиков
UC2577T-ADJ
60 ₽
UC2577T-ADJ
1 731 ₽
Рутоника
UC2577T-ADJ
1 784 ₽
SUV System
UC2577T-ADJ
Pin5
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
Package QTY50
МаркировкаUC2577T-ADJ
Width (мм)8.51
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.7
Duty Cycle(Max)100 %
Iq(Typ)45 мА
Package GroupTO-220
Regulated Outputs1
Special FeaturesN/A
Switch Current Limit(Min)3 A
Switch Current Limit(Typ)4.3 A
Switching Frequency(Max)52 kHz
Switching Frequency(Min)52 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)3 В
Vout(Max)60 В
Vout(Min)5 В
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • DN-49 UC2577 Controls SEPIC Converter for Automotive Applications
    PDF, 61 Кб, Файл опубликован: 5 сен 1999
    The Single-Ended Primary Inductance Converter (SEPIC) can convert an input voltage to an output voltage that is higher, lower, or equal to the input. Conversion is performed without the use of expensive transformers, making the SEPIC a good choice for low-cost, non-isolated applications. The UC2577 provides the switch and control to take advantage of this topology with a minimum of additional part
Серия: UC2577-ADJ (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
UC2577TADJ, UC2577T ADJ
На английском языке: Datasheet Texas Instruments UC2577T-ADJ
