Datasheet Texas Instruments TL594CNE4 — Даташит
СерияTL594
МодельTL594CNE4
Цепь управления широтно-импульсной модуляцией (ШИМ) 16-PDIP от 0 до 70
TL594 Pulse-Width-Modulation Control Circuit datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 30 сен 2016
14 предложений от 14 поставщиков
Чип стабилизации напряжения, Voltage Mode PWM Controller 40V 200mA 300kHz 16Pin PDIP Tube
TL594CNE4
28 ₽
TL594CNE4
33 ₽
TL594CNE4
TL594CNE4
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаTL594CN
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodVoltage
Duty Cycle(Max)45 %
Frequency(Max)300 kHz
Frequency(Min)1 kHz
Gate Drive(Typ)0.2 A
Package GroupPDIP
Special FeaturesAdjustable Switching Frequency,Error Amplifier,Multi-topology
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off6.1/6 В
Vin(Max)38 В
Vin(Min)-0.3 В
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments TL594CNE4
