Datasheet Texas Instruments SN74AHCT244DWG4 — Даташит
СерияSN74AHCT244
МодельSN74AHCT244DWG4
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-SOIC от -40 до 85
SNx4AHCT244 Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.5 Мб, Версия: M, Файл опубликован: 7 ноя 2013
Pin20
Package TypeDW
Package QTY25
МаркировкаAHCT244
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Bits8
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Schmitt TriggerNo
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
На английском языке: Datasheet Texas Instruments SN74AHCT244DWG4
