Datasheet Texas Instruments 5962-8867301KA — Даташит
СерияSN54ALS652
Модель5962-8867301KA
Восьмеричные шинные трансиверы и регистры с выходами с 3 состояниями 24-CFP от -55 до 125
Octal Bus Transceivers And Registers With 3-State Outputs datasheet
PDF, 793 Кб, Версия: G, Файл опубликован: 7 дек 2000
Pin24
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)9.09
Length (мм)14.36
Thickness (мм)1.72
Max Height (мм)2.29
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
LCCC
Package Size: mm2:W x L (PKG)See datasheet (CFP)
See datasheet (CDIP)
RatingMilitary
Schmitt TriggerNo
Technology FamilyALS
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
59628867301KA, 5962 8867301KA
На английском языке: Datasheet Texas Instruments 5962-8867301KA
