Datasheet Texas Instruments SN74LVC00APWLE — Даташит
СерияSN74LVC00A
МодельSN74LVC00APWLE
Четверной логический элемент положительного NAND с 2 входами 14-TSSOP от -40 до 125
SNx4LVC00A Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 1.4 Мб, Версия: R, Файл опубликован: 3 фев 2016
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)0.08 | 1ku
F @ Nom Voltage(Max)(Mhz)150
ICC @ Nom Voltage(Max)(mA)0.04
Тип входаTTL
Operating Temperature Range(C)-40 to 125
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаTTL
Package GroupTSSOP
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)12.5
6.4
5.1
4.3
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > NAND Gate
На английском языке: Datasheet Texas Instruments SN74LVC00APWLE
