Datasheet Texas Instruments TRS3122ERGER — Даташит
СерияTRS3122E
МодельTRS3122ERGER
2Tx/2Rx Низковольтный приемопередатчик RS232 малой мощности 24-VQFN от -40 до 85
TRS3122E 1.8 V Low Power Dual RS-232 Transceiver datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 13 май 2016
Pin24
Package TypeRGE
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаTRS3122
Width (мм)4
Length (мм)4
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)1000 kbps
Drivers Per Package2
ESD HBM15 kV
Logic Voltage(Min)1.65 В
Main Supply Voltage(Nom)1.65 - 5.5 В
Package GroupVQFN
Power Saving FeatureAuto-Powerdown Plus
Receivers Per Package2
  • Evaluation Modules & Boards: BOOSTXL-RS232
    TRS3122E: RS-232 Transceiver BoosterPack
  • Evaluation Modules & Boards: TRS3122EEVM
    TRS3122E: 1.8V RS-232 Transceiver Evaluation Module
  • Designing with the TRS3122E (Rev. A)
    PDF, 189 Кб, Версия: A, Файл опубликован: 23 июл 2016
    As RS-232 continues to withstand the test of time and serial port evolution, standard RS-232 transceivers must evolve to meet current and new system level needs. Applications demand smaller form factor, faster speed, lower power, cost efficiency, robustness, reliability, and ease of use. Most of the current standard solutions (that is, TRS3232, TRS3243, and so forth) meet these needs. Higher speed
Серия: TRS3122E (2)
На английском языке: Datasheet Texas Instruments TRS3122ERGER
