Datasheet Texas Instruments LM6181IM-8/NOPB — Даташит
СерияLM6181
МодельLM6181IM-8/NOPB
Усилитель с токовой обратной связью 100 мА, 100 МГц 8-SOIC от -40 до 85
Datasheet LM6181
PDF, 2.1 Мб, Версия: C, Файл опубликован: 10 сен 2014, Страниц: 39
100 mA, 100 MHz Current Feedback Amplifier
Статус продуктаСкоро будет снят с производства (Производитель объявил о скором прекращении производства прибора)
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаLM6181IM8
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementTHS3120ID
Replacement CodeQ
  • Evaluation Modules & Boards: LMH730227
    Evaluation Board for High-Speed Single Op Amp in the 8-Pin SOIC Package
  • Topics on Using the LM6181; A New Current Feedback Amp (Rev. B)
    PDF, 431 Кб, Версия: B, Файл опубликован: 6 май 2013
    Although it may seem that evaluation of high-speed circuit operation can be more quickly performed withcomputer simulation, full bench evaluation cannot be supplanted. By integrating both of thesecomplementary tools, the cycle time from component selection to finalized design can be reduced.
  • Development of an Extensive SPICE Macromodel for Current-Feedback Amps (Rev. B)
    PDF, 862 Кб, Версия: B, Файл опубликован: 6 май 2013
    A current-feedback amplifier macromodel has been developed which simulates the more common smallsignaleffects such as small-signal transient response and frequency response as well as temperatureeffects, noise, and power supply rejection ratio. Also modeled are large-signal effects such as non-linearinput transfer characteristics and input/ output slew rate limiting.
Серия: LM6181 (3)
LM6181IM8/NOPB, LM6181IM 8/NOPB
На английском языке: Datasheet Texas Instruments LM6181IM-8/NOPB
