Datasheet Texas Instruments V62/06614-01XE — Даташит
СерияUCC2895-EP
МодельV62/06614-01XE
Усовершенствованный продукт Bicmos Advanced Phase Shift PWM-контроллер 20-SOIC от -55 до 125
UCC2895-EP BiCMOS Advanced Phase-Shift PWM Controller datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 20 сен 2017
Pin20
Package TypeDW
Package QTY2000
МаркировкаUCC2895MEP
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)100 %
Frequency(Max)527 kHz
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
RatingHiRel Enhanced Product
Special FeaturesError Amplifier,Soft Start,Soft Switching,Synchronization Pin
TopologyFull-Bridge
UVLO Thresholds On/Off11.8/9.8 В
Vin(Max)17 В
Vin(Min)9 В
  • UCC3895 CD Output Asymmetric Duty Cycle Operation
    PDF, 70 Кб, Файл опубликован: 21 авг 2002
    A small number of current-mode applications using non?synchronous output stages have experienced asymmetric pulse widths on the OUTC and OUTD outputs of the UCC3895. Applications using synchronous rectification and/or voltage mode control typically do not experience this anomaly. For the cost of a single resistor, a simple fix allows reliable and stable operation of the UCC3895.
  • A Comparison Between the BiCMOS UCC3895 Phase Shift Controller and the UC3875
    PDF, 21 Кб, Файл опубликован: 22 фев 2001
    This application report compares the BiCMOS UCC3895 to its bipolar predecessors, the UC3875/6/7/8 family and the UC3879 controller. All of these integrated circuits provide the control and drive signals needed to implement a full-bridge converter using phase-shifted control. The UCC3895 represents the latest offering in the Texas Instruments line of phase-shift controllers, incorporating a feature
  • Synchronous Rectifiers of a Current Doubler
    PDF, 207 Кб, Файл опубликован: 27 фев 2003
    Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary
  • UCC2895 Layout and Grounding Recommendations
    PDF, 393 Кб, Файл опубликован: 9 апр 2009
    The UCC2895 family of Phase Shifted Full Bridge Power Converters Control Circuits are designed to provide efficient power conversion with minimal noise generation. This is accomplished by the resonant switching of the primary side voltages, which minimizes the switching losses and the voltage/current transients that would be present in a hard switched conventional full bridge power supply.
  • Current Doubler Rectifier Offers Ripple Current Cancellation
    PDF, 116 Кб, Файл опубликован: 21 сен 2004
  • A Power Management Solution for Efficient, Multiple Output Applications
    PDF, 293 Кб, Файл опубликован: 4 окт 2001
  • DN-63 The Current-Doubler Rectifier: An Alternative Rectification Technique
    PDF, 81 Кб, Файл опубликован: 12 янв 2001
    The UC3875, UC3879, and UC3895 families of ICs control a bridge power stage by phase-shifting the switching of one half-bridge with respect to the other. This method allows constant-frequency pulse-width modulation in combination with resonant, zero-voltage switching for high efficiency performance. These ICs can be configured to provide control in either voltage mode or current mode operation, wi
Серия: UCC2895-EP (2)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
V62/0661401XE, V62/06614 01XE
На английском языке: Datasheet Texas Instruments V62/06614-01XE
Публикации по теме
