Datasheet Texas Instruments SN74LVC157ADRG4 — Даташит
| Серия | SN74LVC157A |
| Модель | SN74LVC157ADRG4 |
Четверной 2-линейный селектор данных/мультиплексор 16-SOIC от -40 до 85
SN54LVC157A, SN74LVC157A datasheet
PDF, 1.1 Мб, Версия: Q, Файл опубликован: 1 янв 2011
Купить SN74LVC157ADRG4 на РадиоЛоцман.Цены — от 12 до 181 ₽11 предложений от 11 поставщиков IC DATASELCT/MUX 2-1 QUAD 16SOIC. Multiplexer 4 x 2:1 16-SOIC. Logic - Signal Switches, Multiplexers, Decoders | |||
| SN74LVC157ADRG4 Texas Instruments | 12 ₽ | ||
| SN74LVC157ADRG4 Texas Instruments | 181 ₽ | ||
| SN74LVC157ADRG4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | LVC157A |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Полоса частот | 100 МГц |
| Bits | 2 |
| Количество каналов | 4 |
| Configuration | 2:1 |
| Digital input leakage(Max) | 5 uA |
| ESD Charged Device Model | 0.75 kV |
| ESD HBM | 2 kV |
| F @ Nom Voltage(Max) | 100 Mhz |
| Function | Encoder/Multiplexer |
| ICC @ Nom Voltage(Max) | 0.04 мА |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| Тип | Standard |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 13.5,7.4,5.7,5 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC157A (23)
- SN74LVC157AD SN74LVC157ADBLE SN74LVC157ADBR SN74LVC157ADBRG4 SN74LVC157ADE4 SN74LVC157ADG4 SN74LVC157ADR SN74LVC157ADRE4 SN74LVC157ADRG3 SN74LVC157ADRG4 SN74LVC157ADT SN74LVC157ANSR SN74LVC157ANSRE4 SN74LVC157APW SN74LVC157APWE4 SN74LVC157APWG4 SN74LVC157APWLE SN74LVC157APWR SN74LVC157APWRE4 SN74LVC157APWRG4 SN74LVC157APWT SN74LVC157ARGYR SN74LVC157ARGYRG4
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
