Datasheet Texas Instruments OPA658U-1 — Даташит
СерияOPA658
МодельOPA658U-1
Широкополосный маломощный операционный усилитель с обратной связью по току 8-SOIC
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA68XP
    DEM-OPA68xP: Demonstration Fixture
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
OPA658U1, OPA658U 1
На английском языке: Datasheet Texas Instruments OPA658U-1
