Datasheet Texas Instruments THS4140CDGN — Даташит
СерияTHS4140
МодельTHS4140CDGN
Полностью дифференциальный усилитель ввода/вывода с высокой скоростью нарастания напряжения и отключением 8-MSOP-PowerPAD от 0 до 70
High-Speed Fully Differential I/O Amplifiers datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 31 янв 2006
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаAOF
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic83 dBc
3rd Harmonic80 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураFully Differential,Voltage FB
BW @ Acl160 МГц
CMRR(Min)75 дБ
CMRR(Typ)84 дБ
GBW(Typ)170 МГц
Input Bias Current(Max)15000000 pA
Iq per channel(Max)16 мА
Iq per channel(Typ)13.2 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)85 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)450 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)6.7 нВ/rtГц
Vn at Flatband(Typ)6.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)7 мВ
  • Evaluation Modules & Boards: THS4140EVM
    THS4140EVM Evaluation Module
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
На английском языке: Datasheet Texas Instruments THS4140CDGN
