Datasheet Texas Instruments THS5641AIDW — Даташит
СерияTHS5641A
МодельTHS5641AIDW
8-разрядный цифро-аналоговый преобразователь (ЦАП) с быстродействием 100 MSPS 28-SOIC от -40 до 85
8-Bit, 100 MSPS, CommsDAC(TM) Digital-to-Analog Converter datasheet
PDF, 915 Кб, Версия: A, Файл опубликован: 25 сен 2002
28 предложений от 19 поставщиков
IC DAC 8BIT A-OUT 28SOIC. 8 Bit Digital to Analog Converter 1 28-SOIC. Data Acquisition - Digital to Analog Converters (DAC)...
Рутоника
THS5641AIDW
384 ₽
THS5641AIDW
438 ₽
THS5641AIDW
5 039 ₽
THS5641AIDW
Pin28
Package TypeDW
Package QTY20
МаркировкаTHS5641AI
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package Size: mm2:W x L28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Power Consumption(Typ)100 mW
Разрешение8 Bits
SFDR55 дБ
Sample / Update Rate100 MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5641AIDW
