Datasheet Texas Instruments UCC3954DTR — Даташит
СерияUCC3954
МодельUCC3954DTR
Одноэлементный литий-ионный преобразователь в +3,3 В 8-SOIC от -20 до 70
Datasheet
TSP
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • DN-86 UCC3954 Single Cell Lithium-Ion to +3.3V Converter EVM Board
    PDF, 79 Кб, Файл опубликован: 5 сен 1999
    This design note describes the UCC3954 evaluation kit, which allows the designer to evaluate the performance of the UCC3954 Single-Cell Lithium-Ion to +3.3V Converter. The UCC3954, along with a few external components, develops a regulated +3.3V from a single lithium-ion battery in which terminal voltage can vary between 2.5V and 4.2V. The UCC3954 uses a simple flyback (buck-boost) technique to co
Серия: UCC3954 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments UCC3954DTR
