Datasheet Texas Instruments TPS73428DRVT — Даташит
СерияTPS734
МодельTPS73428DRVT
250 мА, низкий ток покоя, сверхнизкий уровень шума, высокий PSRR, линейный стабилизатор с низким падением напряжения 6-WSON
250mA, Low Quiescent Current, Ultra-Low Noise, High PSRR Low Dropout Linear Reg datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 4 фев 2009
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
Accuracy(%)2
Additional FeaturesEnable
Fast Transient Response
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)0.30 | 1ku
Fixed Output Options(V)1.8
3
3.3
Iout(Max)(A)0.25
Iq(Typ)(mA)0.044
Noise(uVrms)28
Operating Temperature Range(C)-40 to 125
Output Capacitor TypeCeramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)28
Package GroupWSON
Package Size: mm2:W x L (PKG)See datasheet (WSON)
Regulated Outputs(#)1
Vdo(Typ)(mV)125
Vin(Max)(V)6.5
Vin(Min)(V)2.7
Vout(Max)(V)6.3
Vout(Min)(V)1.2
RoHSНе совместим
  • Evaluation Modules & Boards: TPS73401DRVEVM-527
    TPS73401DRVEVM-527 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
На английском языке: Datasheet Texas Instruments TPS73428DRVT
