Datasheet ТI THS6132VFP — Даташит
| Серия | THS6132 |
| Модель | THS6132VFP |
Высокоэффективный драйвер линии ADSL класса G 32-HLQFP от -40 до 85
High Efficiency Class-G ADSL Line Driver datasheet
PDF, 469 Кб, Версия: A, Файл опубликован: 27 фев 2003
- Active Output Impedance for ADSL Line DriversPDF, 636 Кб, Файл опубликован: 26 ноя 2002
Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS6132 (3)
- THS6132RGWR THS6132VFP THS6132VFPG4
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
