Datasheet Texas Instruments BQ24100RHL — Даташит
СерияBQ24100
МодельBQ24100RHL
Автономное синхронное импульсное литий-ионное зарядное устройство с полевым транзистором 2 А в QFN-20, 1-элементный 20-VQFN от -40 до 85
bq241xx Synchronous Switched-Mode, Li-Ion and Li-Polymer Charge-Management IC With Integrated Power FETs (bqSWITCHERв„ў) datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 30 ноя 2015
5 предложений от 5 поставщиков
Управление питанием от батарей Switch-Mode Li-Ion Charger
BQ24100RHL
TradeElectronics
BQ24100RHL
BQ24100RHL
727GS
BQ24100RHL
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
# Series Cells1
Absolute Vin (safety rating)(Max)((V))20
Approx. Price (US$)2.00 | 1ku
Battery Charge Voltage(Max)(V)4.2
Battery Charge Voltage(Min)(V)4.2
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)(A)2
Control TopologySwitch-Mode Buck
Operating Vin(Max)(V)16
Operating Vin(Min)(V)4.35
Package GroupVQFN
Package Size: mm2:W x L (PKG)20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
RoHSНе совместим
  • Evaluation Modules & Boards: BQ24100EVM
    BQ24100 Evaluation Module
  • Power Dissipation Analysis & Circuit Design for Sync Switching Battery Charger
    PDF, 402 Кб, Файл опубликован: 31 май 2005
    The bqSWITCHER(TM) (bq24100/03/05/08/13/15) is a highly integrated, switch-mode, Li-ion and Li-polymer battery charger IC. With two power MOSFETs, the gate drivers, and the controller fully integrated in the chip, the circuit design as well as the PCB layout has been appreciably simplified. However, it is still important to have a good understanding of the charger circuit design, layout principles
  • Extending Single Input Charger to Dual Input Applications (Rev. A)
    PDF, 256 Кб, Версия: A, Файл опубликован: 21 сен 2009
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24100 (3)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24100RHL
