Datasheet Texas Instruments TLV2541IDG4 — Даташит
СерияTLV2541
МодельTLV2541IDG4
12-разрядный АЦП, 200 тыс.
2.7 V to 5.5 V Low-Power 12-Bit 140/200 KSPS, Serial Analog-To-Digital Converter datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 12 апр 2010
импульсов в секунду, последовательный выход, совместимость с TMS320 (до 10 МГц), одноканальный. 8-СОИК от -40 до 85
Package TypeD
Package QTY75
Маркировка2541I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаSingle-Ended
Integrated FeaturesOscillator
InterfaceSPI
Multi-Channel ConfigurationN/A
Power Consumption(Typ)2.8 mW
Reference ModeExt
Разрешение12 Bits
SINAD72 дБ
SNR72 дБ
Sample Rate (max)200kSPS SPS
Sample Rate(Max)0.2 MSPS
THD(Typ)-84 дБ
  • Evaluation Modules & Boards: 5-6KINTERFACE
    5-6K Interface Evaluation Module
  • Interfacing the TMS320C5402 DSP to the TLV2541 ADC and the TLV5636 DAC (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 19 сен 2001
    This report shows how to interface TLV2541 and TLV5636 12-bit serial data converters to the TMS320C5402 DSP via the McBSP. It presents a hardware solution and a software solution to interface the 16-bit fixed-point TMS320C5402 DSP to read from the TLV2541 12-bit, 200-KSPS, single-channel, serial analog-to-digital converter (ADC) and to write to the TLV5636 12-bit digital-to-analog converter (D
  • Interfacing the TLV2541 to the MSP430F149
    PDF, 169 Кб, Файл опубликован: 7 мар 2003
    This application report discusses the SPI interfacing implementation of a system featuring the following devices: TLV2541, TLC2551, TLC3541 and TLC4541. These ADCs offer a variety of options for users ranging from extremely low power and wide voltage supply rangeto fast conversion throughput. All devices share a very small (MSOP) footprint and are pin-for-pin compatible for easy upgradeability.
  • Interfacing Low Power Serial (SPI) ADCs to the MSP430F449
    PDF, 407 Кб, Файл опубликован: 4 фев 2005
    This application report discusses the serial peripheral interface (SPI) implementation of a data acquisition system featuring the following devices: TLV2541, TLC2551, TLC3541, and TLC4541. These analog-to-digital converters (ADC) offer options for users ranging from extremely low power and wide voltage supply range to fast conversion throughput. All devices share a small (MSOP) footprint and are p
  • Interfacing the TLV2541 ADC and the TLV5618A DAC to the TMS320C31 DSP
    PDF, 352 Кб, Файл опубликован: 13 ноя 2000
    This application report is written to help design engineers or technicians implement a simple data acquisition system using serial analog-to-digital converters (ADCs) and digital-to-analog (DACs) from Texas Instruments. A hardware and software solution for interfacing the TLV2541 ADC and the TLV5618A DAC to the TMS320C31 DSP with the use of the TMS320C3x DSP starter kit (DSK) is presented here.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV2541IDG4
