Datasheet Texas Instruments LM95245CIMM-1/NOPB — Даташит
| Серия | LM95245 |
| Модель | LM95245CIMM-1/NOPB |
В±2В°C Remote and Local Temperature Sensor with TruTherm Technology and SMBus Interface 8-VSSOP -40 to 125
Precision Diode Digital Temp Sensor w/TruTherm BJT Comp Tech for 45nm Process datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 22 мар 2013
Купить LM95245CIMM-1/NOPB на РадиоЛоцман.Цены — от 34 до 222 ₽11 предложений от 11 поставщиков SENSOR DIGITAL -40C-85C 8VSSOP. Temperature Sensor Digital, Local/Remote -40°C ~ 85°C 10 b (Local), 12 b (Remote) 8-VSSOP. Temperature Sensors -... | |||
| LM95245CIMM-1/NOPB Texas Instruments | 80 ₽ | ||
| LM95245CIMM-1/NOPB Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 1000 |
| Carrier | SMALL T&R |
| Маркировка | T46C |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Interface | I2C,SMBus |
| Local Sensor Accuracy(Max) | 2 +/- C |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rating | Catalog |
| Remote Channel | 1 |
| Remote Diode Temp Range for Listed Accuracy | 50 to 105 C |
| Remote Sensor Accuracy(Max) | 0.75 +/- C |
| Remote Sensor Correction | Beta Compensation,TruTherm |
| Remote Temp Resolution(Max) | 13 bits |
| Special Features | One shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering |
| Supply Current(Typ) | 350 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2.7 В |
| Temp Resolution(Max) | 11 bits |
Серия: LM95245 (7)
- LM95245CIM/NOPB LM95245CIMM LM95245CIMM-1/NOPB LM95245CIMM/NOPB LM95245CIMMX-1/NOPB LM95245CIMMX/NOPB LM95245CIMX/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
LM95245CIMM1/NOPB, LM95245CIMM 1/NOPB
