Datasheet Texas Instruments UCC28811DR — Даташит
Серия | UCC28811 |
Модель | UCC28811DR |
Контроллер мощности светодиодного освещения 8-SOIC от -40 до 105
LED Lighting Power Controller datasheet
PDF, 1.5 Мб, Файл опубликован: 22 окт 2008
![]() 41 предложений от 18 поставщиков IC LED DRIVER OFFL DIM 8SOIC. LED Driver IC 1 Output AC DC Offline Switcher Flyback, Step-Down (Buck), Step-Up (Boost) Triac... | |||
UCC28811DR Texas Instruments | 25 ₽ | ||
UCC28811DR Texas Instruments | 32 ₽ | ||
UCC28811DR Texas Instruments | 65 ₽ | ||
UCC28811DR Texas Instruments | 504 ₽ |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 28811 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Dimming Method | Analog |
Входное напряжение | AC/DC Type |
Iout(Max) | 5 A |
Iq(Typ) | 4 мА |
Рабочий диапазон температур | от -40 до 105 C |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Power Factor Correction | Active Min |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Adjustable Switch Frequency,Soft Start,Soft Switching |
Switching Frequency(Max) | 250 kHz |
Switching Frequency(Min) | 5 kHz |
Topology | Boost,Buck,Flyback,PFC Controller,Sepic |
Тип | Inductive |
Vin(Max) | 18 В |
Vin(Min) | 13 В |
Vout(Max) | 400 В |
Vout(Min) | 9 В |
Vref | 2.5 В |
- Evaluation Modules & Boards: UCC28810EVM-003
110-W Multiple String LED Driver with Universal Line Input and PFC Evaluation Module
- PWM and Analog Dimming Solution to Implement 0.05% to100% Dimming Range UCC28811PDF, 1.7 Мб, Файл опубликован: 17 янв 2014
The PWM and Analog Dimming Solution to Implement 0.05% to100% Dimming Range Based On UCC28811 Constant Current Buck written by Chinese engineer
Серия: UCC28811 (3)
- UCC28811D UCC28811DG4 UCC28811DR
- Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
