Datasheet Texas Instruments TPS70927DBVT — Даташит
СерияTPS709
МодельTPS70927DBVT
150 мА, 30 В, сверхнизкий Iq регулятор с широким входом и малым падением напряжения (LDO) с защитой от обратного тока 5-SOT-23 от -40 до 125
TPS709 150-mA, 30-V, 1-µA IQ Voltage Regulators with Enable datasheet
PDF, 2.1 Мб, Версия: G, Файл опубликован: 4 ноя 2015
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм)0.95
Max Height (мм)1.45
Точность2 %
Основные особенностиEnable,Reverse Current Protection
Fixed Output Options1.2,1.35,1.5,1.6,1.8,1.9,2.5,2.7,2.8,3,3.3,3.6,3.8,3.9,5,6 В
Iout(Max)0.15 A
Iq(Typ)0.001 мА
Noise190 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz26 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Thermal Resistance ОёJA73 В°C/W
Vdo(Typ)300 мВ
Vin(Max)30 В
Vin(Min)2.7 В
Vout(Max)6 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: LMG1020EVM-006
    LMG1020 GaN low-side driver + GaN FET LiDAR Evaluation Module
  • Evaluation Modules & Boards: TPS70933EVM-110
    TPS70933 Evaluation Module
  • Evaluation Modules & Boards: MULTIPKGLDOEVM-823
    Universal Low-Dropout (LDO) Linear Voltage Regulator Evaluation Module
  • Linear power for automated industrial systems
    PDF, 1.8 Мб, Файл опубликован: 9 янв 2015
    Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a
На английском языке: Datasheet Texas Instruments TPS70927DBVT
