Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 5962-8955301SA — Даташит
СерияSN54AS640
Модель5962-8955301SA
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-CFP от -55 до 125
Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 1 янв 1995
Pin20
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)6.92
Length (мм)13.09
Thickness (мм)1.84
Max Height (мм)2.45
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
See datasheet (CFP)
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)(V)5.5
VCC(Min)(V)4.5
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Introduction to Logic
Серия: SN54AS640 (3)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
59628955301SA, 5962 8955301SA
На английском языке: Datasheet Texas Instruments 5962-8955301SA
