Datasheet ТI UCC28511N — Даташит
| Серия | UCC28511 |
| Модель | UCC28511N |
Усовершенствованные комбинированные контроллеры PFC/PWM 20-PDIP от -40 до 105
Advanced PFC/PWM Combination Controllers datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 14 сен 2005
- UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 2PDF, 224 Кб, Файл опубликован: 28 фев 2005
To conclude the review of the UCC28517 PFC supply, this article covers the design of the second 12-V, 8-W power stage to be used as an auxiliary bias supply. - UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 1PDF, 202 Кб, Файл опубликован: 28 фев 2005
Power factor corrected (PFC) preregulators are generally used in ac/dc converters operating above 75 W or to meet line harmonic requirements. This article reviews the design of a 100-W ac/dc power stage with PFC. - Bootstrap Circuit for Green Mode ApplicationsPDF, 111 Кб, Файл опубликован: 27 янв 2006
- A New Synchronization Circuit for Power Converters (Rev. A)PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore - Startup Current transient of the Leading Edge Triggered PFC ControllersPDF, 43 Кб, Файл опубликован: 30 июн 2004
- Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers.
Серия: UCC28511 (4)
- UCC28511DW UCC28511DWG4 UCC28511DWR UCC28511N
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
