Datasheet ТI SN74LVC07ADTG4 — Даташит
СерияSN74LVC07A
МодельSN74LVC07ADTG4
Datasheet Texas Instruments SN74LVC07ADTG4
Шестнадцатеричный буфер/драйвер с выходами с открытым стоком 14-SOIC от -40 до 125
SN74LVC07A Hex Buffer and Driver With Open-Drain Outputs datasheet
PDF, 1.2 Мб, Версия: W, Файл опубликован: 13 ноя 2015
  • LVC07A: Applications Of An Open-Drain Hex Buffer And Discussion Of Char Results
    PDF, 51 Кб, Файл опубликован: 8 апр 1999
    The Texas Instruments (TI) LVC07A hex buffer, with open-drain outputs, and its inverting counterpart, LVC06A, operate in the 1.65-V to 3.6-V VCC range, but can accept input voltages up to 5.5 V. Laboratory results show superior propagation times versus competitors, natural Ioff protection, and output-breakdown capability versus a competitor. Applications of the LVC07A and LVC06A include bus-conte
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC07ADTG4
Политика конфиденциальности
