Datasheet Texas Instruments UC1707J/80313 — Даташит
СерияUC1707
МодельUC1707J/80313
Дополнительные высокоскоростные драйверы питания 16-CDIP от -55 до 125
Dual Channel Power Driver datasheet
PDF, 973 Кб, Версия: B, Файл опубликован: 16 сен 2008
Активная деталь, MOSFET DRVR 1.5A 2Out High Speed Inv/Non-Inv 16Pin CDIP
UC1707J/80313
906 ₽
UC1707J/80313
1 749 ₽
UC1707J/80313
МосЧип
UC1707J/80313
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Channel Input LogicInverting
Fall Time(ns)40
Input ThresholdTTL
Input VCC(Max)(V)40
Input VCC(Min)(V)5
Iq(uA)50
Number of Channels(#)2
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Peak Output Current(A)1.5
Power SwitchMOSFET
Prop Delay(ns)100
RatingMilitary
Rise Time(ns)40
RoHSНе совместим
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-111 Practical Considerations in Current Mode Power Supplies
    PDF, 787 Кб, Файл опубликован: 5 сен 1999
    This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UC1707J/80313
