Datasheet Texas Instruments OPA549S — Даташит
СерияOPA549
МодельOPA549S
Высоковольтный, сильноточный операционный усилитель, отличный выходной сигнал, 11-мощный пакет от -40 до 85
High-Voltage, High-Current Operational Amplifier datasheet
PDF, 441 Кб, Версия: E, Файл опубликован: 7 окт 2005
Pin11
Package TypeKVC
Industry STD TermTO-OTHER
JEDEC CodeR-PSFM-T
Package QTY25
МаркировкаOPA549S
Width (мм)10.7
Length (мм)20.02
Thickness (мм)4.5
Pitch (мм)1.7
Max Height (мм)4.62
Additional FeaturesAdj Current Limit,Shutdown
АрхитектураBipolar
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)0.9 МГц
Input Bias Current(Max)500000 pA
Iq per channel(Max)35 мА
Iq per channel(Typ)26 мА
Количество каналов1
Offset Drift(Typ)20 uV/C
Output Current(Typ)8000 мА
Package GroupPower Package
Package Size: mm2:W x L11Power Package: 90 mm2: 4.5 x 20.02(Power Package) PKG
Rail-to-RailIn to V-
Slew Rate(Typ)9 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer Feedback
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA549 (4)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA549S
