Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS5618PWP — Даташит
СерияTPS5618
МодельTPS5618PWP
Сильноточный синхронный понижающий контроллер с выходом 1,8 В 28-HTSSOP
Synchronous-Buck Hysterectic Regulator Controller datasheet
PDF, 497 Кб, Версия: B, Файл опубликован: 20 июл 2000
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS5618
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
  • Using the TPS56xx To Power DSPs (Rev. A)
    PDF, 61 Кб, Версия: A, Файл опубликован: 7 мар 2000
    The synchronous buck converter controllers (TPS56100, TPS56300, TPS56xx, and TPS5602) made by Texas Instruments are specifically designed to provide excellent transient response and high efficienty to the microprocessor power applications such as the TMS320C6000 and TMS320C5000 DSP families from TI, as well as similar high-speed digital loads. In addition, hysteresis control method is used such th
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS5618 (1)
  • TPS5618PWP
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS5618PWP
