Datasheet Texas Instruments 74AVCAH164245VRG4 — Даташит
СерияSN74AVCAH164245
Модель74AVCAH164245VRG4
16-разрядный приемопередатчик с двойной шиной питания и настраиваемым преобразованием напряжения 48-TVSOP от -40 до 85
SN74AVCAH164245 datasheet
PDF, 857 Кб, Версия: A, Файл опубликован: 6 май 2004
Микросхема Логический контроллер, 16Bit Dual-Supply Bus Transceiver W/Configurable Voltage Translation 48-TVSOP -40℃ to 85℃
74AVCAH164245VRG4
102 ₽
74AVCAH164245VRG4
129 ₽
74AVCAH164245VRG4
74AVCAH164245VRG4
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаWAH4245
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits16
ICCA Static Current0.04 мА
ICCB Static Current0.04 мА
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
Special FeaturesIOFF,Dual Supply,Translation
Static Current0.08 мА
VCCA(Max)3.6 В
VCCA(Min)1.4 В
VCCB(Max)3.6 В
VCCB(Min)1.4 В
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
На английском языке: Datasheet Texas Instruments 74AVCAH164245VRG4
