Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments TMS320C6416TBGLZA6 — Даташит
СерияTMS320C6416T
МодельTMS320C6416TBGLZA6
Процессор цифровых сигналов с фиксированной точкой 532-FCBGA от -40 до 105
TMS320C6414T, TMS320C6415T, TMS320C6416T Fixed-Point Digital Signal Processors datasheet
PDF, 2.0 Мб, Версия: M, Файл опубликован: 6 апр 2009
Pin532532532532
Package TypeGLZGLZGLZGLZ
Industry STD TermFCBGAFCBGAFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY60606060
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка4@2003 TITMS320C6416TGLZA6
Width (мм)23232323
Length (мм)23232323
Thickness (мм)2.612.612.612.61
Pitch (мм).8.8.8.8
Max Height (мм)3.253.253.253.25
DSP1 C64x
RoHSSee ti.com
  • JTAG Emulators/ Analyzers: XDS560TRACE
    XDS560 Trace Emulator
  • Evaluation Modules & Boards: TMDSDSK6416
    TMS320C6416 DSP Starter Kit (DSK)
  • Evaluation Modules & Boards: TMDXEVM6452
    C6452 DSP Evaluation Module
  • TMS320C6455 Design Guide and Comparisons to TMS320C6416T (Rev. A)
    PDF, 369 Кб, Версия: A, Файл опубликован: 8 сен 2009
    This document describes system design considerations for the TMS320C6455 (C6455). It also gives comparisons to designing with the TMS320C6416T (C6416T) for those familiar with that device. The objective of this document is to cover system design considerations for the C6455. Those familiar with the C6416T can use the comparisons to migrate a C6416T design to the C6455. In some cases there is infor
  • TMS320C6414T/15T/16T Power Consumption Summary (Rev. A)
    PDF, 119 Кб, Версия: A, Файл опубликован: 18 фев 2008
    This document discusses the power consumption of the Texas Instruments TMS320C6414Tв„ў, TMS320C6415Tв„ў, and TMS320C6416Tв„ў digital signal processors (DSPs). Power consumption on these devices is highly application dependent, so a spreadsheet is provided to model power consumption for a user's application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low cor
  • Migrating from TMS320C6416/15/14 to TMS320C6416T/15T/14T (Rev. B)
    PDF, 84 Кб, Версия: B, Файл опубликован: 22 фев 2008
    This application report describes issues of interest related to migration from the TMS320C6416/15/14 to the TMS320C6416T/15T/14T device. The objective of this document is to indicate differences between the two device families. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, see the TMS320C6414, TMS320C6
  • TMS320C64x DSP Host Port Interface (HPI) Performance
    PDF, 206 Кб, Файл опубликован: 24 окт 2003
    This application report describes the number of CPU cycles required to perform a given host port interface (HPI) data transfer based on a variety of permutations of burst length, CPU speed, EMIF speed, etc.The HPI provides direct connectivity between a host processor and a CPU?s memory space via a 32/16-bit parallel port. The HPI throughput between a host processor and the TMS320C64xв„ў DSP
  • TMS320C6000 EDMA IO Scheduling and Performance
    PDF, 269 Кб, Файл опубликован: 5 мар 2004
    The enhanced DMA (EDMA) is a highly efficient and parallel data transfer engine. To make the best use of its resources, it is necessary to understand the architecture and schedule transfers intelligently. This document details how to summarize, analyze, and schedule system traffic to produce efficient designs. An example audio/video system is presented and analyzed in full. Finally, EDMA performan
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6416TBGLZA6
