Datasheet Texas Instruments SN74ACT240PWG4 — Даташит
| Серия | SN74ACT240 |
| Модель | SN74ACT240PWG4 |
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN54ACT240, SN74ACT240 datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 7 окт 2002
Купить SN74ACT240PWG4 на РадиоЛоцман.Цены — от 17 до 449 ₽13 предложений от 13 поставщиков IC BUFFER INVERT 5.5V 20TSSOP. Buffer, Inverting 2 Element 4 Bit per Element 3-State Output 20-TSSOP. Logic - Buffers, Drivers, Receivers,... | |||
| SN74ACT240PWG4 Texas Instruments | 20 ₽ | ||
| SN74ACT240PWG4 Texas Instruments | 23 ₽ | ||
| SN74ACT240PWG4 Texas Instruments | 31 ₽ | ||
| SN74ACT240PWG4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 70 |
| Carrier | TUBE |
| Маркировка | AD240 |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 90 Mhz |
| ICC @ Nom Voltage(Max) | 0.04 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ACT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 9.5 нс |
- Understanding Thermal Dissipation and Design of a HeatsinkPDF, 59 Кб, Файл опубликован: 4 май 2011
Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: SN74ACT240 (14)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
