Datasheet Texas Instruments LM3530TME-40/NOPB — Даташит
СерияLM3530
МодельLM3530TME-40/NOPB
Высокоэффективный драйвер белого светодиода с программируемой функцией измерения окружающего света 12-DSBGA
LM3530 High-Efficiency White-LED Driver with Programmable Ambient Light Sensing Capability and I2C-Compatible Interface datasheet
PDF, 7.5 Мб, Версия: L, Файл опубликован: 23 дек 2014
Pin12
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаDX
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов1
Duty Cycle(Max)94 %
LED11
LED Current Per Channel30 мА
Рабочий диапазон температурот -30 до 85 C
Package GroupDSBGA
Peak Efficiency88 %
Shutdown Current(Typ)1 uA
Special FeaturesI2C Control
Switching Frequency(Max)500 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)40 В
  • Evaluation Modules & Boards: LM3530EV-KIT
    Evaluation Board for the LM3530
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
LM3530TME40/NOPB, LM3530TME 40/NOPB
На английском языке: Datasheet Texas Instruments LM3530TME-40/NOPB
