Линейка продуктов KEEN SIDE
Datasheet Texas Instruments AM26LS33ACD — Даташит
СерияAM26LS33A
МодельAM26LS33ACD
Четверной дифференциальный линейный приемник 16-SOIC от 0 до 70
AM26LS32Ax, AM26LS33Ax Quadruple Differential Line Receivers datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 19 сен 2016
Pin16
Package TypeD
Package QTY40
Маркировка26LS33AC
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
ICC(Max)70 мА
Supply Voltage(s)5 В
  • Wave Solder Exposure of SMT Packages
    PDF, 206 Кб, Файл опубликован: 9 сен 2008
    It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
На английском языке: Datasheet Texas Instruments AM26LS33ACD
