Datasheet ТI ADS8327IRSAT — Даташит
СерияADS8327
МодельADS8327IRSAT
Datasheet Texas Instruments ADS8327IRSAT
2,7–5,5 В, 16 бит, 500 KSPS, последовательный АЦП 16-QFN от -40 до 85
Low Power, 16-Bit, 500-kHz, Single/Dual Unipolar Input, ADC w/Serial I/F datasheet
PDF, 1.8 Мб, Версия: E, Файл опубликован: 27 янв 2011
  • Using the ADS8327 with the TMS320C6713 DSP
    PDF, 189 Кб, Файл опубликован: 18 дек 2006
    This application report presents one solution for interfacing the ADS8327 16-bit, 500-KSPS serial interface converter to the TMS320C6713 digital signal processor (DSP). The hardware solution comprises the ADS8327EVM, TMS320C6713 DSP Starter Kit (DSK), and the 5-6K Interface Board. The software demonstrates how to use a McBSP, EDMA, and a timer peripheral to collect data at 500 kHz. Discussed als
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS8327IRSAT
Политика конфиденциальности
