Datasheet ТI CD74ACT05M96 — Даташит
| Серия | CD74ACT05 |
| Модель | CD74ACT05M96 |
Шестигранные инверторы с выходами с открытым стоком 14-SOIC от -55 до 125
Hex Inverters With Open-Drain Outputs datasheet
PDF, 941 Кб, Версия: C, Файл опубликован: 8 ноя 2006
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT05 (5)
- CD74ACT05E CD74ACT05EE4 CD74ACT05M CD74ACT05M96 CD74ACT05M96G4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
