Datasheet ТI ADS7279IRSAR — Даташит
| Серия | ADS7279 |
| Модель | ADS7279IRSAR |
14-разрядные АЦП с низким энергопотреблением, 1 МГц, одинарный/двойной униполярный вход, с последовательным интерфейсом 16-QFN от -40 до 85
LOW-POWER, 14-BIT, 1MHz, SINGLE/DUAL UNIPOLAR INPUT, ADC w/SERIAL INTERFACE datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 17 июн 2009
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7279 (6)
- ADS7279IPW ADS7279IPWG4 ADS7279IPWR ADS7279IPWRG4 ADS7279IRSAR ADS7279IRSAT
