Datasheet Texas Instruments TPS61180RTET — Даташит
СерияTPS61180
МодельTPS61180RTET
Драйвер белого светодиода 1,5 А для ноутбуков 16-WQFN от -40 до 85
WLED DRIVER FOR NOTEBOOK DISPLAY. datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 11 апр 2013
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаCCG
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Количество каналов6
Duty Cycle(Max)94 %
LED60
LED Current Per Channel25 мА
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 9 mm2: 3 x 3(WQFN) PKG
Peak Efficiency90 %
Shutdown Current(Typ)16 uA
Special FeaturesLoad Disconnect During Shutdown
Switching Frequency(Max)1000 kHz
TopologyBoost
ТипInductive
Vin(Max)24 В
Vin(Min)5 В
Vout(Max)39 В
Vout(Min)5 В
  • Extending the Input Voltage Range of the TPS6116x/8x/9x WLED Drivers
    PDF, 124 Кб, Файл опубликован: 12 авг 2009
    The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available
Серия: TPS61180 (4)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61180RTET
