Datasheet Texas Instruments THS4001IDG4 — Даташит
СерияTHS4001
МодельTHS4001IDG4
Усилитель с обратной связью по напряжению, 270 МГц, 8-SOIC от -40 до 85
270-MHz High-Speed Voltage-Feedback Amplifier datasheet
PDF, 879 Кб, Версия: A, Файл опубликован: 25 мар 1999
Package TypeD
Package QTY75
Маркировка4001I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic65 dBc
3rd Harmonic62 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl270 МГц
CMRR(Min)85 дБ
CMRR(Typ)100 дБ
GBW(Typ)270 МГц
Input Bias Current(Max)5000000 pA
Iq per channel(Max)9.5 мА
Iq per channel(Typ)7.8 мА
Количество каналов1
Output Current(Typ)100 мА
Rail-to-RailNo
Slew Rate(Typ)400 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)12.5 нВ/rtГц
Vn at Flatband(Typ)12.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)8 мВ
  • Evaluation Modules & Boards: THS7002EVM
    THS7002 High Speed Amplifier Evaluation Module
  • Evaluation Modules & Boards: THS6012EVM
    THS6012 High Speed Amplifier Evaluation Modules
  • Evaluation Modules & Boards: THS6022EVM
    THS6022 High Speed Amplifier Evaluation Modules
  • Driving Capacitance with the THS4001
    PDF, 51 Кб, Файл опубликован: 25 фев 1999
    Operational amplifiers (op amps) are often used to drive devices that have significant input capacitance such as analog-to-digital converters, cables, MOSFETs, filter networks, etc. The effect of the capacitance is extra phase shift in the loop gain of the amplifier. This phase shift erodes the phase margin of the amplifier and may lead to instability. At high frequency, even a very small capacita
  • THS4001 SPICE Model Performance
    PDF, 149 Кб, Файл опубликован: 14 окт 1999
    This document outlines the SPICE model of the THS4001 high-speed monolithic operational amplifier. General information about the model file structure, performance comparison, model listing, and a brief comment about symbols are included. The listing can be copied and pasted into an ASCII editor, or it can be down loaded by visiting the THS4001 product folder at http://www.ti.com/sc/docs/products/a
  • 10-MHz Butterworth Filter Using the Operational Amplifier THS4001
    PDF, 248 Кб, Файл опубликован: 28 окт 1999
    This application report describes the design of an active 10-MHz second-order Butterworth low-pass filter useful for band-limiting applications. As an active component, TI's operational amplifier type THS4001, which has a bandwidth of 300 MHz, was used. The design of the filter described in this report is typical of proactical applications, and the steps involved in calculating component values ca
  • Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
    This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
Серия: THS4001 (5)
На английском языке: Datasheet Texas Instruments THS4001IDG4
