Datasheet Texas Instruments TUSB6250PFCR — Даташит
СерияTUSB6250
МодельTUSB6250PFCR
Маломощное высокоскоростное мостовое решение USB 2.0 ATA/ATAPI 80-TQFP
TUSB6250 USB 2.0 to ATA/ATAPI Bridge Controller datasheet
PDF, 542 Кб, Версия: E, Файл опубликован: 4 апр 2008
Pin80
Package TypePFC
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Width (мм)12
Length (мм)12
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Application InterfaceATA
ATAPI
IDE
Approx. Price (US$)2.80 | 1ku
GPIO Pins(#)16
Integrated MCU Architecture8051 WARP
MCU Code Space(KBytes)32
MCU Speed(Max)(MIPs)30
Number of Endpoints IN4
Number of Endpoints OUT4
Package GroupTQFP
Package Size: mm2:W x L (PKG)80TQFP: 196 mm2: 14 x 14(TQFP)
Special FeaturesBulk Transfer
Control Transfer
DMA
Interrupt Transfer
Remote Wakeup
Supply Voltage(s)(V)3.3
USB Speed(Mbps)480
RoHSНе совместим
  • TUSB6250 Power Supply Sequencing
    PDF, 39 Кб, Файл опубликован: 24 фев 2005
  • TUSB6250 Bootcode Application Note
    PDF, 573 Кб, Файл опубликован: 7 янв 2004
    The TUSB6250 bootcode is a start-up code stored as a ROM image within the TUS6250 device. An embedded microcontroller starts executing this code after power-on reset. Once the code is running, it loads application firmware from either an external memory device or the USB host controller. After the code has finished downloading, the bootcode releases its control to the application firmware.This
  • TUSB6250 FAQ (Rev. A)
    PDF, 695 Кб, Версия: A, Файл опубликован: 28 янв 2005
    This document is a compilation of frequently asked questions regarding the TUSB6250 USB 2.0 to ATA/ATAPI Bridge Controller.
  • Selection and Specification of Crystals for Texas Instruments USB 2.0 Devices
    PDF, 61 Кб, Файл опубликован: 12 дек 2002
  • Using the TUSBxxxx EEPROM Programmer (Rev. B)
    PDF, 264 Кб, Версия: B, Файл опубликован: 9 июн 2011
  • VIDs, PIDs, and Firmware: Design Decisions When Using TI USB Device Controllers
    PDF, 162 Кб, Файл опубликован: 24 сен 2003
    System designers using TI USB controller devices must make certain design decisions involving the vendor ID (VID) and product ID (PID) of the USB device and the location of firmware. If these are not configured properly, the device will not be enumerated correctly by the USB host.This document discusses how these are handled within a system using one of the TI USB device controllers. These con
Серия: TUSB6250 (3)
  • Semiconductors > Interface > USB > USB Peripheral
На английском языке: Datasheet Texas Instruments TUSB6250PFCR
