Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AHC541PWG4 — Даташит
СерияSN74AHC541
МодельSN74AHC541PWG4
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-TSSOP от -40 до 125
SNx4AHC541 Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.5 Мб, Версия: O, Файл опубликован: 29 сен 2015
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаHA541
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-50/50 мА
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)12,8 нс
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
На английском языке: Datasheet Texas Instruments SN74AHC541PWG4
